Xantia brake caliper 2.0HDI
Carsten S
Re: Xantia brake caliper 2.0HDI
Unread post by Carsten S »
jimmydod wrote:Thank you all for your replies, my calipers are definately not the ones that are supposed to fit I spoke to a very helpful man on phone from a factor who said in 2000 they ie Citroën fitted the same size to 1.6, 1.8 petrols and the 90hp 2.0HDI.
Sorry for posting wrong info. #-o
HDi 90 was never sold in Denmark, only the 110 model with the bigger brakes.
Xantianut
x 121
Unread post by Xantianut »
Ay up, Jim!
What you need is the code number from the caliper. This is cast into the brake pad retainer on the INSIDE, and hides behind the handbrake cable. However, if you've got it off the car, then access will be easy! You may need a wire brush to read the characters. Tell Bigg Red this casting number and you will get the right rubbers. This is what I did...
C5 HDi 110 SX (Fifi 7 or Otterchops)
RIP
Citroen Xantia 1.8i LX (Fifi 6)
BX16TRS (x2) (Fifi 4 and 5)
BX19DTR (Fifi 2)
BX14E (x2) (Fifi 1 and 3)
