Has anyone made an electric (or other) pre-heater for veggie fuel?
If so, how?
I know about the water based ones using the radiator/heating circuit but these are no good until the engine is warm.
Veggie oil pre-heaters
Have a look here: http://www.implosionresearch.com scroll down the page and click on Plymouth Bio-fuels then click on view products. These should help with running your car. I have been using V100 without any heaters for about a year now and have not had any problems just make sure you fuel filter is in good condition, change it if in doubt.
Take a look at this item. Robin
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... eName=WDVW
Goto
www.dieselveg.com
I've covered 3000 miles in my 406 1.9td (Bosch Pump) running on pure rape oil from Lidl.
What you need to do is shell out £400 on a proper kit that allows you to run on pure diesel until the engine is hot. Then it's fine to run on the oil (46p/l).
The switch over valve has an electric heater fitted and the system comes with a fuel heater heated from the engine coolant.
Save loads (but make sure you register with Customs & Excise).
Takes a weekend to fit.
Runs sweet as a nut.
Sounds quieter too.
Tom[;)]
www.dieselveg.com
Sounds quieter too.
Tom[;)]
