Citroen c8 coolant leak.
Marty762005
Post by Marty762005 »
Hi guys, does anyone have any idea what the part is called that the expansion tank joins to at the back of the engine, its a plastic elbow/flange attached to the engine block by 2 bolts.
Car is a c8 2.2 hdi 53 plate.
Mine has given up and has split just above the bottom bolt .
Many thanks in advance.
Even if it's not broken, over-engineer it !!
x 5743
Re: Citroen c8 coolant leak.
Post by GiveMeABreak »
Hi and welcome.
Do you have your VIN handy as there are 2 variants with the 2.2 and again with transmission type etc....
It looks suspiciously like the Engine Water Intake Tank to me - Part 3 on the diagram - but would need to confirm once I get your VIN.
Marty762005
Hi yes i have the vin, do you need it all ? Its a manual trans
Marty762005
Yes thats the part, is it common for these to crack do you know ?
x 5743
I would prefer as the parts are all different for the engines and the different cooling systems. Send me a PM if you don't want to post it here - I mask the VINs any way as soon as it arrives. I can get you the part number then and a price.
Marty762005
Vin number VF7**************[VIN obfuscated, can be read by forum staff]********
Reason: VIN Masked
x 5743
Ok, so confirmed you have the DW12TED4 engine and the part was correct:-
Water Intake Tank - Part No: 1336R0 (digit 0 not letter O) priced at: £ £29.03 inc. VAT
You'll also need the Coolant Manifold Gasket - Item 4 on the diagram) Part No: 133983. Priced at: £2.53 inc. VAT
Both these are still available from Citroen.
Marty762005
Thank you so much my friend , you are a legend !!!!
x 5743
No worries good luck with it - I like the C8s - cracking vehicles.
Marty762005
love it myself an i only picked it up today ........ and broke it !!!
x 5743
Well there's plenty of help and advice here if you need it in future.
