Coding replacement RT3 - cant find ECU in lexia
Moderator: GiveMeABreak
- x 5808
Re: Coding replacement RT3 - cant find ECU in lexia
I need to see the full text as unfortunately, these early systems do not have full config data, but please see my edit to my last post, as I added a few questions on.
- Donor 2023
- x 24
Its an RT3 with MP3 function to give it the proper name (HDD etc) . Yes its properly wired up inc the dev cable. It was working till i switched something off (and yes ofc, you warned me). I`ll go take a new photo
- x 5808
RT3 or RT4 Simon? The thread says RT4, but the wiring and connections, therefore settings are different.
So it was working ok, then you took a flight of fancy and decided to change something that you can't remember and it's now gone toes up - does that sum it up?
- Donor 2023
- x 24
Almost - it was working in another vehicle, went to put it in mine - again screen was working, went to code it in , changed something and its gone toes up - utterly my fault i know.
- Donor 2023
- x 24
which does mean a little forum trickery to move this to RT3 forum and title change
- x 5808
I'll sort that as it's confused me coming back to the topic Simon and I'm looking at the wrong resources.
- Donor 2023
- x 24
Its me, i will admit i was wrong (and stubbornly so), i was convinced its an RT4 , and it isnt. So Marc i apologise for that.
Its a RT3 with HDD and MP3 ability.
- x 5808
Ok, no worries all sorted now, but what I need is a page by page screenshot of the current configuration pages of the RT3, so I can see the option and the setting.
Also, please confirm you have the Colour version and not the monochrome version of the RT3.
- Donor 2023
- x 24
Its colour, software version is 6.63 . Taking photos shortly in diabox
- Donor 2023
- x 24
- x 5808
Ok leave it with me while I go and get a G&T for this one.
- x 5808
Screen one. Should not have hands free kit with telematics unit.
Screen 2 RADIO - this should be set to absent with a telematics unit IIRC. This should only be active for standard RD4 radios.
Screen 9 - Deflation Detection should be present for your 3.0 litre.
Parking assistance should be active Front & Rear.
Aux Video input - suspect this should be missing.
- Donor 2023
- x 24
no deflation - 3 of the 4 sensors went bad so i had them all removed, yes i can put new ones.
radio now remvoed , hands free now removed
parking assist has dodgy wiring at the front somewhere i think, so doesnt work anyway
aux input now off
aux input now off
- Donor 2023
- x 24
Holy Thread resurrection - as a final note, sent bsi/ecu and keys off to be reflashed and paired to a chap in wales and voila, solved the problem. Lesson learnt
