Condensor & Radiator fans not running - C5 HDi
Post your Cit/Peu/Ren air conditioning queries or advice.
amjake
Unread post by amjake »
All relays changed, fuses tested and checked, crud wiring changed.
Engine running the aircon is working but the Condensor fan and Radiator fan are not.
Testing both fans show them to be working.
So any suggestions as to why they don't run when engine and aircon running and a solution would be appreciated.
Cheers
Kevin
Clogzz
x 40
Unread post by Clogzz »
Clocking up an unnecessary post to tell you that I don’t know yet on the C5. :?
If the fan blade display works but the fan’s not spinning, it’s usually caused by a faulty fan drive output transistor … somehow just like on the Xantia. :twisted:
2002 C5 2.0i AL4 239,000 km 76372389
amjake
Aircon now working perfectly!
Fault was down to more crud wiring, replaced and job done!
Cheers
