f00lzz wrote:Hi Guys.
Need a new auxillary belt... Citroen say that for my model (A/C) there are two available depending on A/C ompressor manufacturer. I am unable to identify a manufacturers plate.... any other clues such as shape etc that I can identify which compressor I have???
Thats a Delphi / Harrison compressor, if you look on the label where is says "Part" you've managed to rub off part of the part number but what is left is the end of it reading 290, the full number should be 1135290. I did the same thing when I cleaned the label off on mine. Although my part number (1135253) isn't exactly the same as yours, my compressor is essentially the same thing, the difference being the external connections.
Just looking at the photos, you seem to be missing the caps off the air con service connectors....
