HEATER DISPLAY BULBS
WELSHVIKING
x 4
Unread post by WELSHVIKING »
All the bulbs seem to be out on the heater display on my xantia hdi sx, how easy a job is it to get behind the display and replace the bulbs and how many bulbs am i looking at...or hopefully it is a common problem which one of your fine members has a quick fix for......and yes i have tried knocking / belting / swearing and spitting at the dash but no response...thanks Colin
x 94
Unread post by citronut »
what about a welsh miners lamp on your helmet,ha ha ha,if they are like ZXones they are easy,just pop off the facure pull the bulbs out using pliyers gently so as not to brake the bulbs fit new ones bobs your whatsit dodars your aunt
regards malcolm
WELSHVIKING
x 4
Thanks Malcolm, will have to see how easy it is to pop out theheater facia, sounds easy but i will bet its not, probably held in by a dozen screws which you can not possible get at......Colin
CURRENT CARS:-
2018 CITROEN C4 PICASSO BLUE HDI FEEL 120BHP (WIFES CAR)
2020 CITROEN C3 AIRCROSS 1.2 FLAIR PURETECH 130BHP AUTO (MY CAR)
Jshodgson
Unread post by Jshodgson »
Mine have never worked and then after a year they came on a couple of weeks ago!!!! Now they need some gentle persuasion with my foot !!!
"Its character building, owning a Citroen"
Had (Saxo VTR 1999 (T) LPG converted - do not ask!!!)
Had (Xantia LX TD 1995 (M) 144,000 miles)
Had (Xantia TD Estate (N) 147,000 miles !)
NOW GOT Picasso 2.0HDi (02) 96,000 miles
Clogzz
x 40
Unread post by Clogzz »
WELSHVIKING wrote:probably held in by a dozen screws which you can not possible get at
Possibly not, the Haynes book has good pictures of that.
I fiddled with that years ago, and it was no rocket science.
The surround trim unclips easily, then there are 4 screws to undo, and it slides out.
If the globes twist into contacts tinned with solder, all of them may need a good scrape.
