GSF lists one type only perportedly for all XM. The XM microfisch says new bearing type from org 7477 (spring '97). My XM 2.5TD is from march 98 and has org 7777. Will the GSF bearing fit? and if it does, will the hub fit the bearing (the hub was also changed at the same org for a stonger construction)?
//NiSk
