XM 2.5TD water pump belt
greatgatsby
Unread post by greatgatsby »
Has anyone had any experience of the water pump belt letting go on an XM 2.5TD?
Having done it once and been replaced, it did it again after about 100miles. Any ideas?
AndersDK
Unread post by AndersDK »
How long has the waterpump been in service ?
greatgatsby
164k, but it seems OK from spinning it over.
AndersDK
164K (miles) would be close to the average service life of a waterpump, but they might as well pass the 200K limit no problems.
It's important to check a waterpump for any slight lateral movement of the axle, as this indicates a gross failure just round the corner, and might explain any mysterious friction during running.
Having scared you away with this, I have to say it could simply be a bad belt or the belt wrongly tensioned. Belt tension should be like any alternator belt - not like the scaringly tensioned HP pump belt.
