Can anyone please tell me where the outside temperature sensor is located on a 1992 XM SEI ?
Regards, Roger.
Apologies for the delay in posting this; many thanks for the replies.
I can report that it is not in either the O.S. or N.S. mirrors.
N.S.F. wheel arch will be attacked when time permits.
Cheers, Roger.
Edited by - RogerReed on 20 Oct 2002 03:08:11
XM SEI temp. sensor.
NiSk
Inside the left hand rear view mirror. If you look closely, you'll see a small loop of wire hanging down under the middle of the mirror glass. Pull this down while at the same time being prepared for the glass to release. Once you've got it out, the means by which it is held in place becomes obvious.
//NiSk
//NiSk
Zummerman
Roger,
Check this out, plenty of useful information!
http://www.andyspares.com/discussionfor ... PIC_ID=281
Good luck!
Good luck!
