Spare parts for Citroen BX BE1 gearbox?
kdnielsen
Post by kdnielsen »
Hello
I am renovating a Citroen BX 1,6 TRS BE1 gearbox from 1988, and I am trying to buy a new syncromesh for the 1 and 2. gear.
My Citroen dealer tells me, at that they are not produced anymore, and that he can only get it from Peugeot for around 350 pounds!
Before I move into the world of jetfighter spare part prices, could anyone please tell me, if there is a cheaper alternative.
dnsey
x 19
Post by dnsey »
Yes - replacement box!
You should be able to get a really good one from a breaker for under £50.00.
AndersDK
Post by AndersDK »
Try also C15 (the Visa commercial van) and almost any frontwheel driven Peugeot model same year models with the 16/19 engines.
Dont expect these cars to float around at the breakers however - as they dont stock the cars that long any more.
I doubt you can get any help at all from your Citroen (or Peugeot) dealers as they only stock parts with a reasonable turn-over.
Customers coming in asking for a set of new syncro rings really arent that common these days [8)]
Found this on PR-net
Parts drawing number :
1230 01 334610 / PRIMARY SHAFT-PINIONS-SYNCHRONISERS / ESSENCE ET CARBURATEUR ET 1,580L ET 1,905L JUSQU'A OPR 04529
drawing reference :
06 / 2353 60 / 01 / SYNCHRONIZER
07 / 2388 04 / 01 / SYNCHRONIZER
I believe it's reference 06 above you need for 1.st & 2.nd gears.
It's not exactly a set of simple friction rings, but a rather complex part.
x 93
Post by citronut »
or you might have a good gear box specialist round abouts where you live,i know of one near where i live
regads malcolm
kdnielsen
Post by kdnielsen »
Hello All
Thank you very much for the excellent replies. Well done!
I am working in all the directions suggested and I will give you a resume, when I get to the end.
Also I am working on a solution that involves machining a piece of aluminium plating (lathe?) and riveting or screwing that in place instead of the worn ring. After all, that is the only part of the syncromesh, which is worn.
jeremy
Post by jeremy »
I haven't looked at the diagrams on this but imagine your problem is that the cone surface has worn away. Often these are bronze and it may be possible for you to get fresh bronze deposited (I use that loose term deliberately - may be by MIG or gas or metal spraying processes) by a specialist engineer who will then be able to machine it to the correct shape and surface.
Jeremy
kdnielsen
Post by kdnielsen »
Dear Jeremy
The syncromesh is not done vith a cone.
It is done with an aluminium ring which, when engaged, is brought in contact with a steel cup. The friction between the ring and the cover is what makes the syncronisation.
The fault is not, that the ring is worn down. Instead it has buckled between the places where the rivets fixates it. I suspect metalfatique har turned the aluminium soft and flexible.
jeremy
Post by jeremy »
That'll teach me to guess!
Jeremy
fastandfurryous
x 4
Post by fastandfurryous »
If you can find a BE3 gearbox in bits in a scrapyard somewhere, I seem to remember reading somewhere that they (BE3's) had an improved design of synchromesh. Might be easier to do a straight swap of a part rather then go machining bits. maybe?
