Paint Codes Citroen C5 (Facelift Model)
jmd
Post by jmd »
Damaged the rear passenger door on my Citroen C5. I have located a door some 100 miles away, Unfortunately the guy who is selling the door does not know the colour code. (except that it is silver as in mine) He has supplied me with the Registration Number & the VIN Number of the donor car, in the hope that I might establish the colour code through same.
I have trawled the web to solve my problem without success !. Can anybody help, if I supply Vin No, & or reg no. (N.I Reg NO)
VertVega
x 13
Re: Paint Codes Citroen C5 (Facelift Model)
Post by VertVega »
PM the VIN Number and I'll get you paint code.
jmd
Post by jmd »
Many thanks VertVega. Just sent you a PM with information.
VertVega
x 13
Post by VertVega »
Replied :) As I have written there it's EZR - GREY ALUMINIUM METALLIC.
jmd
Post by jmd »
Thanks again VertVega. Just after sending you a PM. Paint code on my car is EZRC. It seems the donor car is just EZR. I wonder does this make a difference.
VertVega
x 13
Post by VertVega »
Yes same paint code. Your's should be written as EZRC** if you check it carefully :)
jmd
Post by jmd »
Correct....VertVega. It is EZRC**. So my problem is solved. Many thanks.
wallbanger
New User
Post by wallbanger »
Hello, were can i find the colour code in my citoen c5 2005 1.6 hdi
jmd
Post by jmd »
The paint Code is usually written on a label attached to the body of the car inside the drivers door. Open the Drivers door and the label will be seen attached to the door pillar (at front). Normally comprises four letters.
