citroen xantia immobiliser problem
Hi i have a citroen xantia 1.8 1996. I put my key in the ignition today and put my code in the immobilser it flashed green and bleeped 3 times but now the car turns over but doesnt start also the head lights have started flashing when there not even on. Ive tryed it again and now the green light comes on the immobiliser when i turn the key and dont even put the code in. If anyone could help me on this it would be much appreciated thanks joe. Also the car is struggleing to turn over now thought it was the battery dying but its not as all the lights stereo etc are working fine.
- x 5
Are the indicators flashing along with the headlights? On earlier xantia models, which didn't have the immobiliser keypad, this was part of the security system. Have you recently disconnected the battery for any reason, which would trigger the alarm system?
Edit: Welcome to the Forum - I'm sure someone will be able to help with this
Martin
1995 Xantia TDLX (deceased )
- x 71
Headlights Flashing means the ALARM is SUPPOSED to be sounding, but either A, the sounder is dead, or B the sounder it switched off under the bonnet-- the key switch is in the upperright hand side of the scuttle trim (passenger side, UK cars)
You'll need to reset your alarm, SIMPLE with a plip, but if that does not work, its still possible..
NO PLIP: Locate on the dash, behind the wiper stalk the button with a sounder and a CROSS through it... put your key in the ignition. Then open the bonnet and disconnet the EARTH terminal.. Wait a sec, then reconncect. Then firstly, go in the car then while HOLDING THE button with the X trough it, turn on the ignition - The indicators SHOULD then flash to tell you that the alarm is reset...
With a PLIP, every time you open the car with the PLIP it does this operation automatically for you.
Try that, then try your code again.
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 77
EDIT... I see citroenxm posted the same time as me , although I'll leave my reply incase it provides any help, although his is more likely to work.
That's the alarm system typically.
Note: I'm only used to Peugeots, so most of this still applies but things may be in a different place.
The keyswitch under the bonnet disables the siren or perhaps that part is broken, no matter.
Lock car.
Unlock car, get in shut the door, turn on ignition (2nd position do NOT attempt to start) and press the alarm cancel button within a few seconds, You need to be quick to do this. That should stop the lights flashing and you should be able to start the engine now. You have to do all this within a few seconds.
The alarm button is likely to be on the column cowling or on the centre console. It looks a bit like two or three (( lines but upright. I do not seem to be able to find a picture of one.
Lock car.
Andy.
- x 71
Andy, Need to disconnect the battery first to make it effective..spider wrote: Unlock car, get in shut the door, turn on ignition (2nd position do NOT attempt to start) and press the alarm cancel button within a few seconds, You need to be quick to do this. That should stop the lights flashing and you should be able to start the engine now.
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 93
the head lights flashing is what happens on disconecting the battery then reconectting,
in this case i have sorted it out by just turnning on the ignition then within a couple of seconds press and hold the button to the right of the steering wheel Paul mentioned,
you might find what caused this on your car is maybe the battery only just had enough curent to turn the starter
regards malcolm
regards malcolm
- x 71
If you do not get to the ignition quick enough...... you get about 15 seconds after connection before it all breaks loosecitronut wrote:the head lights flashing is what happens on disconecting the battery then reconectting,
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 77
I'll take your word for it. My "method" did bring many an errant 306 under control though. To be fair they were the very early ones, so I'd guess they revised the system slightly.citroenxm wrote: Andy, Need to disconnect the battery first to make it effective..
Paul
Good to learn and know anyway
Andy.
