Free Citroen Mechanics Handbooks
x 1869
Post by GiveMeABreak »
Citroen have a range of mechanics handbooks available, mostly for some models before and up to 2005 that are freely available to registered users. To make these more easily available to others, I have assembled the available resources into a table below with links to relevant PDF file which you can download.
These are in English and in PDF format. These are currently only available for the models listed, so please don't request them for other vehicles / models / years. They are not yet currently available for Peugeot, but I expect them to be available shortly covering similar years. When they are available, I will create a similar document and post it under the Peugeot section.
The info flows left to right to left in alphabetical / model order, bearing in mind that some years are not available for all models.
Click on the Year for the vehicle you want and then choose the option to download the file. Please bear in mind that some models of vehicle are covered in the same document for some years (i.e. C5 and C8), but these have been listed separately to avoid confusion - so don't be surprised if the document covers more than one model - just make sure you go to the right section within the document.
Berlingo PrivateYear & LinkBerlingo UtilityYear & Link
Berlingo Private2001Berlingo Utility2001
Berlingo Private2002Berlingo Utility2002
Berlingo Private2003Berlingo Utility2003
Berlingo Private2004Berlingo Utility2004
Berlingo Private2005Berlingo Utility2005
C1Year & LinkC2Year & Link
C12005C22003
C3 PlurielYear & LinkC22004
C3 Pluriel2004C22005
C3 Pluriel2005C4Year & Link
C3Year & LinkC42004
C32002C42005
C32003C5 MK IYear & Link
C32004C5 MK I2000
C32005C5 MK I2002
C5 Mk IIYear & LinkC5 MK I2003
C5 Mk II2005C5 MK I2004
C6Year & LinkC8Year & Link
C62005C82002
Dispatch I & IIYear & LinkC82003
Dispatch I & II2001 C82004
Dispatch I & II2002C82005
Dispatch I & II2003Relay I & II, C15Year & Link[/tv]
Dispatch I & II2004Relay I & II, C152001
Dispatch I & II2005Relay I & II, C152002
SynergieYear & LinkRelay I & II, C152003
Synergie2001 Relay I & II, C152004
Synergie2002Relay I & II, C152005
Xantia S2Year & LinkXM S2Year & Link
Xantia S22001 XM S22001
XsaraYear & LinkXsara PicassoYear & Link
Xsara2001 Xsara Picasso2002
Xsara2002Xsara Picasso2003
Xsara2003Xsara Picasso2004
Xsara2004Xsara Picasso2005
Xsara2005EOLEnd of List
x 952
Re: Free Citroen Mechanics Handbooks
Post by white exec »
Marc,
A big thank you for pulling all these documents together, and overcoming a couple of technical issues in linking to them.
This is genuine and authoritative technical service/parts replacement information, which can be relied on.
It also adds (eg in the case of suspension spheres) full spec information not always found elsewhere (such as sphere damping figures).
Some of the service information is extremely detailed - eg timing belt replacement - and is a really good step-by-step mechanic's guide.
Some part numbers listed will have changed since the documents were issued, but these are easily checked and updated.
The documents are all high-quality PDF, so readily printable to any size required.
A great job, Marc.
x 1869
No problem Chris - I hope members find the info useful to have all in one place. :)
Donor 2016
x 730
Post by Stickyfinger »
Good Job Marc, is this being added to ?
donor 2020
x 660
Post by Gibbo2286 »
Thanks for that Marc, very handy.
x 1869
I'll add these as any more become available chaps - but it would seem that at present, they are only releasing earlier models pre-2005. I'll keep an eye out though.
x 112
Post by wheeler »
I have a stack of these in the original paper format going back as far as 1988 but don't have any newer than 2005 don't know if they producing them or just the paper format? They have been on Citroen service for years now so would have hoped any newer ones would have been released by now which is a shame. Does anyone know if any newer models are on the paid service?
They have also pretty much stopped all tech documentation/wiring diagrams in paper format, the last original paper workshop manuals for a new model that im aware of was the C8.
x 952
Could you post a list of the paper books you have, so that we can check whether they might plug any gaps in the assortment of those available online on service.citroen?
x 112
Post by wheeler »
I'll need to go through some boxes in my garage to see what else I have, from memory the majority range from 97 to 04 with a few oddball ones before 97. A lot of them are similar but just model year updates.
I sold a lot of older ones I had on ebay a few years back.
x 952
Thanks, that will be interesting.
Wonder what year they started to produce these, and for what early car?
x 112
Post by wheeler »
A quick glance through the 88 one shows it covers AX, Visa, BX, CX & AXEL ?? Whatever that is??
x 952
Citroen AXEL was a new one to me too.
https://en.wikipedia.org/wiki/Citro%C3%ABn_Axel
That '88 document is interesting in itself, as it covers models prior to what is on serv.cit. now - where the oldest seems to be C15 and XM.
It would be well worth our digitising these older booklets, to add to what we already have.
Am happy to scan here, but I'm sure something more local would be better!
moizeau
donor 2020
x 123
Post by moizeau »
Thanks very much for the list Marc, much appreciated, just got the 2005 c8 manual because it references my engine and it's always good to research cam belt changes from as many good sources as possible.
picassodad
x 7
Post by picassodad »
wow the wife spotted this thread as she was just looking over my shoulder, will get a new usb stick and start saving........thanks.
justn had a quick look inside the one for the lads picasso, loads of info which will take some reading, brilliant and thanks again.
x 1869
picassodad wrote:
03 Nov 2018, 11:34
Although the build date of your Picasso was 23/11/2001 - it should still have everything relevant in the 2002 model handbook. :)
