Heated seats stopped working
- EDC5
- My Cars: Citroen C5 RHR AM6
- x 120
Re: Heated seats stopped working
Is the key the same frequency? There are 433MHz and 434MHz types depending on age.
Have you attempted to synchronise the remote function?
- Cutac
- My Cars: 2011 B7 Citroen C4 1.4 VTi
2006 Citroen C4 2.0 VTS - x 20
According to the aliexpress listing, it's a 434Mhz model.
I did try to synchronise, using various methods, but neither of them worked.
- Cutac
And according to my VIN on service.citroen:
LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
But on the plaque I recieved with my car keys(when I bought the car), it says 433Mhz key made by Delphi.
Can that be changed in Diagbox maybe?
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5646
Because it probably isn’t compatible with the earlier system in your C4. The circuitry and software have to be compatible with the car’s architecture. It’s like trying to use tech from a 1995 chip to work with a car today, only in reverse.
- Cutac
But it's weird since I've got the same 3 button key and it works from the factory.
I've checked few cars on service(2011, 2013 and 2014, which is exclusive) and all have that same 433.92 Mhz frequency. So how come are my factory keys 433 MHz?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok 2 separate things going on here. There is the transponder chip for the starting of the car. Then there is the remote locking and unlocking using the fob and optionally a middle button for lights or boot opening etc.
So although the transponder chip has been coded and paired successfully, the other electronics for the remote function may not.
- Cutac
Yeah, I know that, but I have a three button key from the factory and it works, but the exact same one from aliexpress doesn't.
If my car has 434MHz reciever, how does the factory 433 MHz key work?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
But are you understanding? The MHz is just the frequency the remote is operating on. If it is not sending the right information it won’t make any difference, i.e. it may be sending garbage if the BSI us not understanding the message, regardless if the frequency!
Let’s clarify something first. When you paired the new key with Lexia. Did you pair ALL the keys together in the same session?
If you did this then your Ali key is probably not compatible.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I've moved this to a new topic as it is a completely different subject. Please make any new posts concerning the Key Fob on the new thread here:
viewtopic.php?f=3&t=60763
- Cutac
So I've peeked under the seats and wiggled the cables, but no luck. Some day I'll buy a new fuse and replace it. If that doesn't work, what next?
I'll check the Diagbox tomorrow.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
It's cheap enough to try the fuse first - but then if that is not working, it may be possible that the wire under the carpet as per my diagram has become damaged or broken while you were giving it a good clean!
- Cutac
Maybe there's an actuator test for heated seats in the Diagbox.
I'll update after I try something.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
No actuator test for heated seats Cutac - they don't have any tests, but check Fuse F7 in the interior fusebox - I've been checking some other info out for you:
Also, I don't know what the temperature is with you where you are, but....
- If the temperature in the inside cabin is 30° C or over, the function is deactivated:
Each seat has a temperature sensor (incorporated in the seat cushion) which exercises control independently through the regulation control unit for each seat. Position 3 on the heating control dial corresponds to a maximum seat cushion temperature of 40°C above which the heating of the seat is stopped. If the passenger compartment temperature is above 30°C, the temperature inside the seat can still reach 40°C and so prohibit the heating of the seat. - If the heated seats are not operating properly, the electrical power management system can request deactivation of operation of the heated seats with the aim of keeping the battery voltage level higher than or equal to 12,8V (Load reduction function)
- Cutac
It's been over 30 degrees here for a while.
I could be interior sensor that's faulty, but then the Air con would act up, wouldn't it? Would it show a fault in the Diagbox? Diagbox shows three faults: two are side lights because of LEDs and one is P1644, speed limiter fault(don't know how to fix that).
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
The way to test it is go out in the evening when it is cooler and see if they work then.
