- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5725
Assuming you have replaced it with the exact same engine then it will be fine.
Item (9) is unfortunately no longer available - which is probably why it has been badly bodged. If they have connected the pipes together then of course it is going to leak with pressure build up.
You may need to try and get some pipe made up or modify a similar pipe.
The original part was: 1180K9.
- Rp0thejester
- My Cars: C8 2.2 Hdi Exclusive
- x 807
Ah, that explains it, thx for the info. So nowhere does that hose?
Champion of Where's CitroJim
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3007
As the part is no longer available it could be worth calling into Pirtek with (if it can be safely removed) that item 9 pipe, to see if they could make up a replacement. You don't have much to loose, and a safely working engine to gain.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Rp0thejester
- x 807
That's exactly what I was thinking!! Pirtek or any other hydraulic hose company. I've destroyed many a hose on a Brokk
- Rp0thejester
- x 807
Thx for the info Marc, that was what I was expecting. My garage told me the brake pipe lines aren't available, is that correct??
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Officially no - they have stopped making that part now as the car is over 16 years old. It really depends on what the part is and the demand.Rp0thejester wrote: ↑04 Jun 2022, 18:50 Ah, that explains it, thx for the info. So nowhere does that hose?
I forgot to mention the dimensions for you:
DIAM 12X16 LONG 245
- Rp0thejester
- x 807
Thx that will help alot, so the internal diameter is 12mm?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Again, it depends on which pipes you need - some are and some aren't:Rp0thejester wrote: ↑04 Jun 2022, 19:03 Thx for the info Marc, that was what I was expecting. My garage told me the brake pipe lines aren't available, is that correct??
Available: 1, 2, 7, 8, 9, 10, 11, 14, 15,
Unavailable: 5, 6, 12, 13
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Yes
- Rp0thejester
- x 807
I know it's a stupid question, but I'm a diamond/core driller. The amount of times I'm told internal dimensions rather than the external dimensions...
- Donor 2023
- x 3007
One of my (myriad of) sayings is "There is no such thing as a stupid question". If you don't have the information you require you have to enquire.Rp0thejester wrote: ↑04 Jun 2022, 19:15 I know it's a stupid question, but I'm a diamond/core driller. The amount of times I'm told internal dimensions rather than the external dimensions...
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Rp0thejester
- x 807
Great anology, my fav is Fail to plan Plan to fail. But I always say to anyone, if you don't know ASK! Nothing worse than them get it wrong!! If you don't know ASK!!! It takes a real man to ask for help, kids struggle
- Donor 2023
- x 3007
I have an addendum to that saying; "...but stupid, avoidable mistakes do exist".Rp0thejester wrote: ↑04 Jun 2022, 19:37 Great anology, my fav is Fail to plan Plan to fail. But I always say to anyone, if you don't know ASK! Nothing worse than them get it wrong!! If you don't know ASK!!! It takes a real man to ask for help, kids struggle
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Donor 2023
- My Cars: 1987 Volvo 480 ES
2006 Citroen C6 3.0 petrol Exclusive - x 48
Thanks very much. Got a second hand on the way now. Cheers.GiveMeABreak wrote: ↑04 Jun 2022, 17:23James, if this is for your VIN ending 665, then there were 2 options - a locking cap and a non-locking cap:jamescarruthers wrote: ↑04 Jun 2022, 16:43 Hello all. My sister has managed to loose the fuel filler cap for her 2001 2.2 C5… it’s the magnetic type that tells the car to inject Eolys fluid so I’d better get it replaced pronto!
Can I have the part number, please, and is it still available to buy from Citroen? If not I’ll get a second hand one.
(6) Locking
Combination specified on order, part: 1508J4, £72.88
Random Combination, part: 1508J3, £101.77
(10) Non-locking was part: 1508F7, £19.09, but no longer available.
1987 Volvo 480 ES
- Lexia Available: Yes
- My Cars: 605 V6 SII
406 D9 SV
Xantia SX wagon SII
Xantia Activa TCT (unregistered) - x 217
Hi all
I have a D9 406 SV, VIN VF3**************[VIN obfuscated, can be read by forum staff], which is currently refusing to start. The starter no longer spins - best I was able to get was a very weak part-turn. This has been brewing for a while, but at first it was just occasionally, and after a few retries it would suddenly just work.
It is definitely not the battery - it's showing 12.7 volts. Just to be sure I connected jumper leads from a running vehicle - measured voltage at 13.8v - no difference.
Now I realise that there are other possibilities, but is 438087 the right starter motor? Looks like Spareto could fly one out to me for about $100 less than I could buy one in Australia.
Cheers
Alec
Cheers
Alec
