Marc: Do you have the drive belt length? There are a few sizes and I can't get to car ATM to measure.
206 head gasket
Re: 206 head gasket
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: 206 head gasket
No, length is not listed. They don't provide detailed dimensions as the part number is generally sufficient. Some aftermarket suppliers will state 991 mm and other 1075mm in length - so be wary of this.
Citroen's original belt is usually a Gates brand from personal experience, but they are currently £66.24 for the 0816F2 part and £33.34 for their approved cheaper brand from Eurorepar at present.
Re: 206 head gasket
Work is all done on the 206. Skimmed head new Elring head gasket kit, Gates timing belt kit and water pump, auxilliary belt, new coolant obviously, oil and filter change, air filter, new T/Stat, Bosch spark plugs. Going good then a phone call. Won't turn over. Starter motor out and it was dead. New starter motor fitted and all good. What a tight job that is to replace starter. Need new steering control arms next. £59 a pair for Febi ones..........that'll do nicely.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- CitroJim
- My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
- x 6204
- Contact:
Re: 206 head gasket
If an 8V TU it's a doddle of a job... One of the easiest HGs to do...
16V version is not hard either... Oil leaking out from the front of the head gasket joint on an TU engine is standard. They all do it... Except my two that is! The only dry TU engines I know
Runner, cyclist, time triallist, duathlete, Citroen AX fan and the CCC Citroenian 'From A to Z' Columnist...
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1379
Re: 206 head gasket
We scrapped my daughter's 16v 1.4 206 rather than have the hassle of fixing the oil leak from the head gasket. Maybe, in retrospect, that was bit hasty.
Re: 206 head gasket
May be lack of coolant changes with the gaskets going. Not a bad wee engine really the 8v. Only 51k on this.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- CitroJim
- x 6204
- Contact:
Re: 206 head gasket
Yes, like all PSA engines, they do like to have their coolant looked after...
I love the TU, it's such a happy, revvy little engine with a big sense of fun and adventure
I love them so much I'm happy to overlook their occasional incontinence issues
Re: 206 head gasket
An update on the PUG. Starter from ECP. A Remy item which is AC Delco. After going ok for a few days it is not throwing the pinion. Tap with hammer and it goes. All out again for a replacement. PITA. Will put a Bosch one in.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: 206 head gasket
Lexi - I've lost count of the number of times many of us have mentioned it here, but I'll repeat it again - your main issue is ECP. Avoid like the plague - I've yet to hear of anything thing from this company that hasn't turned up damaged, broken, non-functional or the wrong part. The only thing I will ever buy from them if I have to - is various branded cans of aerosol sprays and lubricants - never any parts, mechanical or electrical.
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
Re: 206 head gasket
I would recommend GSF over ECP every day of a Leap Year.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Re: 206 head gasket
I don't doubt it Marc. I needed a starter that day and GSF have no Glasgow branch now, and nearest is Hamilton. There is a TMS at the airport, but I haven't tried them yet. I have been getting good service and parts from Mr Auto and Car Parts in Motion on Ebay. A lot of the places around here have gone. Partco and Brown Bros were my go to for many years. Don't come to Scotland Marc................nothing but scenery , rain and midgesGiveMeABreak wrote: ↑08 Oct 2020, 10:38 Lexi - I've lost count of the number of times many of us have mentioned it here, but I'll repeat it again - your main issue is ECP. Avoid like the plague - I've yet to hear of anything thing from this company that hasn't turned up damaged, broken, non-functional or the wrong part. The only thing I will ever buy from them if I have to - is various branded cans of aerosol sprays and lubricants - never any parts, mechanical or electrical.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: 206 head gasket
Sounds wonderful! You can keep your rain though, I've plenty of Welsh rain here
Re: 206 head gasket
Following on from Marcs theme. The second starter from ECP was a Valeo rebuilt in Poland. Screeches like a cat on engaging. It is like a sharp crack/scream. WTF? Daughter says to leave it in............she has had enough I phoned manager and logged the fault and complaint.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Re: 206 head gasket
Removed Valeo starter and worked it with remote battery. Noise at first then ran fine. Used high quality grease and went over pinion and shaft after winding it to the stop. Tried again off the car, better. Put on car again...........seems fine now.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Re: 206 head gasket
Marc: Wonder if you can check if the Pug has ABS on the rear drums? It is an auto so may have extra braking. Is it a Lucas or Bendix system? Maybe just what they fit on the day of course. Fitted an A2A Exhaust from GSF today on it. Long middle pipe and silencer. Not a good fit IMO. Oh well ..........it is quiet at least.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
