16 is the bonnet lock. The radiator is fitted on elastic dowels (2), so is designed to be firm but slightly pliable - but not enough to move it like you describe.
C5 X7 Radiator burst
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
Re: C5 X7 Radiator burst
- white exec
There should be very little movement of the radiator - perhaps just a couple of mm, against the rubber bushes.
- bobins
- Donor 2023
- My Cars: Kia Sportage
Mazda BT-50
Land Rover SIII SWB
V-F-R800
SL320
MX5 - x 2888
When I checked mine yesterday, the push-fit location lug at 4 (above) was slightly out of its socket. Nothing drastic, but it just wasn't sitting where it was designed to go and didn't seem to want to sit snugly.
Sadly no longer a C5 owner
I think your radiator is a freak accident. I have had a look at mine. And there are no screws that could cause this situation.
- My Cars: Citroen C5 X7 20 HDI 2010
Renault Megane 3 1.5 2006 - x 3
But, in the bay, there is one confusing tube, (also for "expert")... it is unattached on one side, and we do not know for what it is, and where should go..
Can somebody give some idea... it is tube next to the battery, after ribbed one... tin black hose, with yellow ring some ⅝0cm from end of tube (look at photo). Other end enters black box on top of engine, were injectors are...but where should other go!?
I took the car 20 min before... 10 I'm city ride,.. temp 97'C - fan kicks in - 95'C still working... looks normal, just when I parked, sow some wapor going little bit around lights... open the hood, but I think it is vaporising humidity from antifreeze spiled all over bay... will see tomorrow.
Conclusion from service is that there is nothing wrong... everything working fine, no explanation for radiator burst... just happeneđ...
tnx
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I am trying to identify it - and so far the only thing I can see vaguely near the top cable is the injector harness:
car is working normally... today city ride... temp never rised over 80'C ... no errors... but this hose rimaned under unatached... and now worm is biting me what should it be...Auto industry don't waste hoses just for fun...
As I can see here are only cables... this was rubber hose some 3-5mm inner diam (luce vacuumm ones)... no idea still... Should I try to dismantle everything to see were it starts?GiveMeABreak wrote: ↑04 Sep 2019, 16:45 I am trying to identify it - and so far the only thing I can see vaguely near the top cable is the injector harness:
- white exec
Yes, what you have is a pipe, not a wiring/harness.
See whether you can identify exactly where the pipe leads to on the engine block.
