It seems when I have all the doors open for a wile
and keep it unlocked for a bit
When I get in it to drive the internal alarm keeps
going off
How do I stop the internal alarm
I’ve stopped the van got out ( unlocked it and locked
it, it sometimes works but not all the time
Internal alarm
Re: Internal alarm
Citroen Berlingo 2015
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: Internal alarm
What do you mean exactly by "internal Alarm"? Do you mean the horn / sire under the bonnet and the direction lights start flashing? If not, what are you referring to?
Re: Internal alarm
No lights flashing or horn
Just a beeping in cab
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Internal alarm
That sounds like either a seat belt not fastened, or door open warning. Check all your doors are clear of obstacles and that nothing is in the way of the tailgate catch.
Are you getting a message on the display or a warning lamp?
Re: Internal alarm
No warning but will check doors next time thanks
Re: Internal alarm
Hi
The same beeping again checked all doors and the beeping
Sometimes when you lock it up and reopen it stops b
But not all the time
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Internal alarm
Can't really help without a video - there are just too many possibilities.
Re: Internal alarm
This is the video of the internal alarm could it be anything to do with the back internal light being on for a long time while the rear doors are open
Reason: Fixed YouTube Links
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Internal alarm
Ok, that makes more sense now!
It's your Head Unit. This can happen when the battery has been disconnected for more that 2 minutes.
To fix it, hold all the 3 buttons in (Menu, Vol- & Vol+) above the display together for 20 seconds or so until the unit screen goes blank. Let the buttons go and when it restarts that should solve it.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Internal alarm
For future reference, if you ever need to replace the battery or disconnect the battery for any reason, follow the correct procedure to ensure that the ECUs have time to write their data and shut down before disconnecting the power:
