Good morning all.
I need the nylon washer/Bush that goes on this and sits in the recess in the boot.
Does anybody know where I can get one from or have one for sale.
Also, I'm looking at making a new hanger bolt out of threaded rod (mine isn't seized, just a pain.to undo)
Does anybody have the length and thickness of the said hanger??
As per. Any info would be greatly appreciated..
Many Thanks
John Brassington.
Xsara Picasso spare wheel hook and hanger
- My Cars: pug306, citroen picasso
- x 14
Re: Xsara Picasso spare wheel hook and hanger
I would try a citroen dealer or parts place, but be prepared for it to be out of stock/no longer available if the car is over 10 years old, too old for citroen spares it seems. Mr citroen will be spinning in his grave me thinks.
I cannot remember what drive the rod has, but maybe weld a nut on the end the same size as the wheel nuts, after removing the threaded rod first.
Maybe visit a breakers for the bush??
God i wish the lads picasso was as an easy fix as this.....
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5648
Contrary to the above - these parts are all showing as available from Citroen. It always pays to ask
The wheel carrier (1) part 7603J5: £106.37
The washer (2) part 761554 £0.82
The Spare wheel support Hook (4) part 761571 £19.78
The spare wheel support fix screw (71) (223mm long) part 7615A4 £8.86
The buffer (74) part 698349 (27mm) £22.51
All the above inc. VAT
- My Cars: Xsara Picasso 1.6hdi
Would I be able to order the parts I require online?
- Michel
- My Cars: Some cars and a motorbike
- x 659
There was a chap over on the Berlingo forum making these bolts out of stainless some years ago. I had one on my Berlingo. Great idea!
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
You can order them from any Citroen dealer via the phone - you have the part numbers I have given you. Or use these part numbers see if you can find any on the aftermarket. Normally if these are no longer supplied or available they will mark them as such - but all these are showing as available.
