I thought some of you might be interested in this
Late Xantia 2 /C5 conversion to Xantia fittings for both front and rear cylinders.
Made up by Big Mick Butler at http://www.Eurocarcare.net" onclick="window.open(this.href);return false;.
parts@eurocarcare.co.uk
A Very helpful chap
Xantia Suspension pipe Rpo 8209-8518
- Donor 2023
- My Cars: '00 Xantia 110 bhp Hdi SX Estate 65K "W"
'99 Xantia 110 bhp Hdi SX Estate 310K SORN "V"
'98 Xantia 1.9TD SX Estate 150K Sold "T" - x 47
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Re: Xantia Suspension pipe Rpo 8209-8518
Some one else on here needs one of those as he has had a top like yours for his xantia!!
Still need to have the 8mm Adapter too for them... to connect to the original pipe on the car...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Donor 2023
I hope he finds this then:-)
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
Should do.. I linked his topic to this...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Donor 2023
Thanks Paul.
For info The pipe on the conversions above are 7cm long. They're a bit short from ideal. If anyone is thinking of doing this I'd recommend 14cm of pipe to the union as the pipe on the Xantia has to bend almost immediately after exiting the union.
I cable tied my pipe to the anti roll bar inside another rubber pipe to prevent chafing.
There's a small rubber o ring which appeared in the drain pan after I'd removed both unions from their cylinders. Any idea where that goes? Not sure if it fits between the C5 union and cylinder or does it fit on the end of the C5 union (beside the green seal above)
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- Donor 2023
You need the o ring between the pipe and the cylinder to form a tight seal.. So be careful.. its only about 4mm across and a right b***er to get into place upside down.
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
