Citroen Xantia Power Steering Pipe Repair Kit.
Forum rules
Please do not include personal contact details (addresses or phone numbers) in your posts or they will be removed. Please use the Private Messaging system to ask for or to provide this information.
- Contact:
DESIGN CHANGE
Due to a couple of factors, I have decided to make a minor adjustment to the repair kit. It will in no way affect its performance, but should increase reliability. Instead of two M12x1 fittings, there will now only be one, and three of the M10x1 fittings. The M12x1 adaptor has also been replaced with another M10x1 adaptor.
The main reason behind the change, is that the M10x1 fittings are available in a "long" format, and therefore allow a better seal to be made. The M12x1 fitting is still required for the Power Steering Pump.
Up for your delectation today, we have a CUSTOM designed and made replacement for the Power Assisted Steering Hose on the Citroen Xantia.
I purchased the car, knowing it needed work. The previous owner had been quoted in the region of £500, 2 days, and that wasn't a guaranteed fix either. It took a few £££'s to get it right, and arguing with the hydraulics company I used, but in the end, I made the replacement myself, as I kept getting told that it wasn't possible.
This is guaranteed to fit as a direct replacement for the rusted and corroded one your car currently sports. I know this, as mine is doing so at the moment!
Supplied in the package will be;
1x SAE 100R2S-AT 2 Wire Reinforced Hydraulic Hose complete with Swivel fittings.
2x Custom machined M10x1mm fitting
3x M10x1mm Long 3/16 Fitting
1x M12x1mm 3/16 Fitting
This neat little package will have your power steering and LHM leakage sorted in no time at all, being a direct replacement.
PLEASE NOTE
THESE ARE MADE TO ORDER IN HOUSE AND WILL TAKE APPROX. 1 DAY TO MANUFACTURE!
NO FITTING INSTRUCTION ARE SUPPLIED, HOWEVER, THE PROCESS IS STRAIGHT FORWARD!
NO KUNIFER/COPPER PIPE IS INCLUDED BUT CAN BE SUPPLIED AT EXTRA COST.
The price I hear you scream? Delivered to your door for £40!!
PLEASE NOTE
- Dommo
- My Cars: Current
07 C5 VTX+ 2.2 HDi 173hp
97 S1 Activa
06 Boxster S
93 XM 2.1 Turbo SD
Previous cars
91 Toyota Soarer UZZ32 Active Suspension
97 S1 VSX 1.9 Turbo D
99 Xantia Activa
98 2.1TD Xantia
99 306 - x 19
Re: Citroen Xantia Power Steering Repair Kit.
Is this a replacement for the curly wurly bit of piping between the gearbox and chassis that fails on phase 2 cars?
Cheers
Cheers
- Contact:
Yes Dommo.
The above pictures show the replacement rubber section, which turns this into a 3 piece solution rather than the discontinued one piece affair from Citroen.
I can provide tha CuNiFer at an additional cost of £10, bringing it to £50 delivered to your door. I can flare the ends of the CuNiFer for you in this price too!
- falling-out-with-my-car
- My Cars: Citroen C5 Aircross 8 speed Automatic, Flair Model with far to many toys and nice comfy armchair like leather seats. ha ha Ive just had a conversation with the car. setting everything up verbally
- x 24
Re: Citroen Xantia Power Steering Pipe Repair Kit.
can you clear this up for me please? (as your pics don't seem to be working) is this the rubber flexi hose that comes from the accumulator
to supply the power steering ?
Thanks in advance.
Nigel.
Thanks in advance.
Nigel.
- x 18
I think so.
Sent from my LG-D855 using Tapatalk
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
- Donor 2023
- My Cars: '00 Xantia 110 bhp Hdi SX Estate 65K "W"
'99 Xantia 110 bhp Hdi SX Estate 310K SORN "V"
'98 Xantia 1.9TD SX Estate 150K Sold "T" - x 47
Hello Mardybum,
Sorted out my PAS pipe with your splendid replacement. Had very little trouble once I'd identified the correct pipe... The cunifer ends were about 10-15 cm too long so I ended up coiling them, one in the wheel arch and one in front of the sump. I used fuel pipe to stop the chafing and zip tied the rest.
Thanks,
Thanks,
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
- CitroJim
- x 6204
- Contact:
Good to hear this was fully successful for you Chris, excellent
- New User
- My Cars: Citroen Xantia V6 Exclusive (manual conversion),
Citroen Xantia HDI Exclusive,
Citroen Dyane.
Hi
I'm after a pipe for my Xantia HDI Exclusive. From the following description are you to tell whether or not it's the pipe that you manufacture please?
There are two pipes coming from pump it's the right hand one looking at it from front of car. It drops down and goes to rubber then to metal along n/s chassis rail. Think it supply's the rear suspension.
If it is, how do I order one from you please?
Richard
Richard
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1300
- Contact:
Welcome,
note above: Tell us more about the conversion...........
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- New User
Citroen Dyane.
Thanks for the welcome. I bought the V6 from RD Motors (Richard Dickinson?) in Yorkshire just over a year ago. It's registration is V6 BDR and it had already been converted by a previous owner, apparently some Xantia enthusiasts already know of it. It's done 150k miles now but still drives very well and is quite tidy. I don't use it on a daily basis but do use it regularly and particularly for long journeys.
- My Cars: C6 3.0HDi Exclusive
SM 3.0 manual 1972
DS 23 Pallas 1975
GSA Pallas C-Matic 1982
C3 Pluriel 2009 - x 4
If this V6 manual Xantia is silver in colour then it's probably the one converted by Fil van Delft (usually of CX fame). I had a ride in it when he brought it to the XM/Xantia rally at Little Horwood a year or two ago.
The car's original auto gearbox had failed and Fil prefers to,shift gears himself, so he converted it.
Shaun
C6 3.0 HDi Exclusive - 2010
SM 3.0 - 1972
DS 23 Pallas - 1975
GSA Pallas C-Matic - 1982
C3 Pluriel - 2009
SM 3.0 - 1972
DS 23 Pallas - 1975
C3 Pluriel - 2009
- Stickyfinger
AX, little Daffodil
- Contact:
Best of luck getting the part, interesting conversion
- CitroJim
- x 6204
- Contact:
I had a long and interesting conversation with Fil discussing the conversion of that car at the rally...
- chinkostu
- My Cars: N Xantia 1.9TD SX
03 Fiesta 1.4 Zetec - x 30
It is a bloody nice car, he still needs to give me a drive of itStickyfinger wrote:Best of luck getting the part, interesting conversion
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
