Clio noisy from cold
Good evening I'm new here,anyway this my last throw of the dice. The engine had a bad ticking rattling noise from the cylinder head. The noise was apparent from start up,all the way through the revs. It was the same hot pr cold. So I changed the cambelt,tensioner,roller, waterpump and vvt pulley all brand new. Fitted new hydraulic liftera as well. Problem now is the engine still has the tapping noise? initially from start up then it kinda quites down abit as it idle. As aoon as u rev it up the noise gets louder, all the way through the revs,sounds as if something might come through the tappet cover. Any ideas to a solution would be gratefully appreciated,thank u.
Reason: Split from Laguna thread
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
Re: Clio noisy from cold
Welcome OmLebz.
I have taken the liberty of splitting your post from the original thread into a thread of it's own to avoid confusion.
Hope this meets with your approval and you receive some answers soon.
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 835
For the avoidance of confusion, can you be more specific about which type of engine your car has?
Evening, tnx steve. its the 1.6 16v engine clio 3. Its raining outside will post engine code when it subsides abit.
