Bluetooth problems
Moderator: GiveMeABreak
Bluetooth problems
Hi,
I have a 2014 Citroen Relay 2.2 and I have a problem with the bluetooth. It did start to play up a bit a while ago, every time I tried to connect was telling me that couldn't find the connection; Now has stopped altogether, there is no connection and the switches on the steering wheel, other than the volume and the track selector, do not work and the odometer started flashing therefore every time that I have to use the phone I have to stop and switch off the engine.
Any thoughts?
Any thoughts?
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: Bluetooth problems
Yes, a common problem - these have a completely annoying Fiat system in as they are Fiat Ducatos essentially.
I did a bit on this issue witht he Fiat influence on this post - read it through to the end as you will see it also happens on the other FIAT affair - the NEMO:
viewtopic.php?f=48&t=58900
I have no documentation on these systems as they are mostly FIAT systems.
- My Cars: Citroen c3 64 plate 1.4 D
I need help if anyone can help i have a Citroen c3 64 plate bluetooth been fine and now sometimes paring is unsuccessful can anyone help tried reseting both devices and clearing conntectes devices
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Post up your VIN, and details of your Mobile phone (Make, model and name / version / of your Android or IOS system software.
Will get vin soon but using
Andriod galaxy s10
Andriod galaxy s10
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I'll need the VIn as soon as you can, but to find the software version of the S10 follow this guide:
https://devicehelp.singtel.com/samsung/ ... e-version/
Android version 9 got s10 brand new earlier the year my partner who has exact phone couldnt connect now she cant and i can had car 1 year im 2nd owner and i was first to use bluetooth via radio so barely used
No sure what part is vin but this all what is written on windshield
Dot 39 as1 m91
43r 001409
E000189
......4
Dot 39 as1 m91
43r 001409
E000189
......4
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
The VIN is on the log book or outside on windscreen passenger lower corner in the cutout. It will begin VF7**************[VIN obfuscated, can be read by forum staff] and is 17 alphanumeric in length.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok,m so you have the RD45 in your C3.
A couple of things you can do:
1) Unpair all bluetooth phones from the RD45 and your Samsung Galaxy 10.
2) Try again to pair the phone
3) Make sure you select the correct Bluetooth profile when pairing and make sure you enter the correct pin within the time if asked.
4) Be aware that it will take some time for the RD45 to synchronise contacts and address book info - so no good expecting to have it all there instantly - it can take half an hour or longer depending on the amount of information and music you have.
Yeah i have tried all them for reason doesnt wotk all it says failure to connect and when try pair from phone says check phone setting but i have thoroughly and its all sweet not sure what else could a reset or switch fuses and also was wondering why sometimes my car does a cerntain amount of miles on mini clock then resets ovbsly not total millage
Thanks.
Thanks.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
The Galaxy S10 is not one of the phones tested by PSA to guarantee compatibility - bu that does not mean it shouldn't work. Make sure you are on the latest phone software.
There are no fuses / switches to reset apart from a BSI reset:
BSI Reset / Battery Disconnect / Reconnect Procedure
As for the mileage - are you sure you're not getting one of the trip counters mixed up with the main mileage counter - the odometer will always maintain total miles, but the other displays are for Trip 1 or Trip 2, or could be the miles remaining on fuel left in tank or even miles to next service etc.
Do you not have a handbook for the car?
Okay will try reset and yeah i do doesnt mention problems with bluetooth or trouble shooting
