C5 sunroof stuck quick help please
Hi all,
Thanks for looking, tried opening the sunroof today and it when into the tilt stage. Now i cannot shut it, if i change try to move it in any direction it almost closes and then decides to go back to where it is. I need to get the sunroof closed. Anyone know what could be wrong it was working fine last week so im thinking electrical not mechanical , can i reset the computer for it any how, any ideas much appreciated thanks
- mooseshaver
- My Cars:
Re: C5 sunroof stuck quick help please
Does pressing and holding button to close for around ten secs help? ThatS how you reset the anti pinch on the windows
C5 III Tourer 2.0 HDi 163 Auto Exclusive
Gone cars.
C5 2.2 HDi Exclusive Estate auto 57. Awesome car. Sadly Could not be fixed by Citroen.
C5 1.6 HDi VTR Estate 56. Traded in.
C5 2.2 HDi SX Estate 02. Drowned in the floods of 09.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
Do sunroofs still come with a manual override facility? As I recall there would be a way of turning the motor by hand, usually with a removable cover over the bit you need to turn.
Some silicon lubricant might help matters too.
Richard
No French cars of my own at present.
Care of a 1994 205 D.
The sunroof is operated by a dial. So i cant hold the button in. It almost closes then decides to open. Maybe it thinks its jamming. I left the battery disconnected over night but no luck
I have fixed my car. I pulled down the roof console and popped out the switch that controls the sunroof, its a round dial type. I noticed it was moving when in the closed position at its own will must have been a loose connection. i played with it and put it and back and now works so just a dodgy switch i think.
if any one else has this problem hope it helps
Sorry for digging up an old topic, but actually the dial can be pressed and held to make the sunroof move.
I found it out by accident when my sunroof got stuck. My Finnish handbook had no mention of sunroof since it wasn't available here, so i had to learn by trial and error. There wasn't even a mention of the fuse.
I managed to get the sunroof moving when pressing the dial, but only when it was in an extreme position. Pressing when it was in the closed position had no effect.
The sunroof moved towards the selected extreme position as long as i pressed the dial, and after i forced it to both ends, it sprung back to life.
If anyone could verify this procedure from an owners manual, i'd be thankful. Info of the fuse would be nice too.
My '03 2.2 HDi is imported from Germany, and when i bought it (already in Finland) the sunroof didn't work. There was a mention in the Finnish registration papers that the "opening sunroof is not allowed with side airbags" or something like that. Luckily the only thing done to disable the sunroof was that the connector of the dial was disconected
- Bandit12
- My Cars: C5 X7 diesel exclusive
- x 12
Hi. The sunroof dial works on a star shaped washer held against the circuit board by a spring. Over time the spring loses tension and the star shaped metal loses proper contact. Solution is to either replace the switch or take it apart and stretch the spring. Also rebounding the star shaped metal contact will help.
Hope that helps
Bandit
Hope that helps
Bandit
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone)
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade)
- Bandit12
- x 12
Oops meant to say re bending the star shaped metal. Predictive text! The star shaped metal should be curved but this also goes flat over the years. Very easy to bend with fingers back into the correct shape
The sunroof switch on my C3 seems to work or not depending on which side you press and how hard (and perhaps on the phase of the moon). I have got the switch dangling on its wire from the roof, but I can't see how to dismantle it - I'm looking to check the spring as mentioned above. Are there any tricks to opening the switch up ?
Thanks, Greg.
Thanks, Greg.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Post up your VIN and I'll see if I can dig out a diagram for you
VIN = VF7**************[VIN obfuscated, can be read by forum staff]
Thanks.
Thanks.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Hi Greg
I've had a good look, and as expected, they don't detail any modular components internally, as these are deemed to be replacement units as expected.
I can tell you that the part is still available from Citroen, should you not have any luck and is Part No: 6554 Q3. Number 7 in the diagram below, in the UK it is priced at £46.69 ex. VAT (20%) or £56.03 (inc. VAT) as a guide. I'll replicate the re-initialisation procedure here in case you haven't tried this first:
Initialisation should be followed in the following cases:
1st case: The sunroof moves rearwards (anti-pinch)
Perform the following operations:
Perform the following operations :
- Position zero "0" of the rotary button does not correspond to position zero of the reduction motor (roof closed position)
- The sunroof does not open using the rotary button
- The sunroof does not close, because of the anti-pinch
- Wait 5 seconds, after it has stopped moving rearwards
- Press on the rotary button until the sunroof closes
- Maintain pressure on the rotary button for 2 to 3 seconds
- Release the rotary button
- Press on the rotary button until the sunroof closes (to trigger the reduction motor relay)
- Perform the following operations :
- Place the rotary button in the maximum open position
- Press on the rotary button until the sunroof reaches the maximum open position
- Without pressing it, place the rotary button directly on position zero "0" (if the sunroof moves, recommence the re-initialisation procedure)
- Press on the rotary button until the sunroof closes (the movement takes place after 1 second)
Thanks GiveMeABreak, a very comprehensive reply.
I still couldn't open the switch, so I gave it a squirt of WD-40 and re-installed it. And now it works. It does look like a flaky connection inside the switch.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Result - but at least you have the procedure here for future reference if needed.
Bandit12 wrote: ↑03 Jul 2017, 12:21 Hi. The sunroof dial works on a star shaped washer held against the circuit board by a spring. Over time the spring loses tension and the star shaped metal loses proper contact. Solution is to either replace the switch or take it apart and stretch the spring. Also rebounding the star shaped metal contact will help.
Hope that helps
Bandit
would it be possible Mr. Bandit to elaborate in more details how to dismantle the switch, I've had a look on and gave it a try but it seems a bit complex. Thanks in advance.
