DPs Fault 1 hour before MoT.....
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1299
- Contact:
I quote:
Lack of coherence between the control and the measured turbocharging pressure.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- Stickyfinger
AX, little Daffodil
- Contact:
Re: DPs Fault 1 hour before MoT.....
I am assuming this needs replacing.
Citroen Part No 1618 X2 ELECTRO VALVE 3V
https://www.ebay.co.uk/itm/OEM-Turbo-Pr ... 1906874201
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 835
The valve will have a foam filter on the atmospheric port. If this is blocked, you will get over-pressure faults.
- Stickyfinger
AX, little Daffodil
- Contact:
Cheers....Will check that....
I read some say Turbo Vanes sticking...
- My Cars: MK2 '17 C4GP 1.6 BlueHDi 120
'13 3008 1.6 HDi GripControl - x 1003
That can cause it too, just put the light out and don't rag it to the station and you should get a pass!! Not sure what engine you have got - on the 1.6 Lighty reckoned that if you pushed the actuator down and it didn't spring right back then the vanes were clogged up (which is easy on that engine as it is right on the front!).
- Stickyfinger
AX, little Daffodil
- Contact:
It is the 2ltr 138 with filter....poverty spec engine
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Not quite poverty spec. better than the 110.....
Fault P11AA
Turbocharger pressure regulation solenoid valve control: Incoherence between the command and the measured turbocharging pressure. Incoherence between the position of the turbocharger solenoid valve and the measured turbocharging pressure for 3 seconds: With the engine running, the airflow must be below 40 kg/h compared with the theoretical flow for 3 seconds.
Downgrade Modes:
Fault P11AA
Downgrade Modes:
- Deactivation of the coherence faults of the flowmeter
- The ECU stops the regulation of the EGR valve
- The engine ECU limits the fuel flow
- Deactivation of the speed limiter
- Deactivation speed limiter until the next time the ignition is switched on
- Deactivation of the cruise control
- Deactivation cruise control until the next time the ignition is switched on
- The activation of the regeneration of the particle emission filter
- The ECU stops the regulation of the turbocharger : Change to piloted mode
- Noise
- Diesel fuel consumption a bit higher
- Lack of power
- Turbocharging pressure sensor
- Turbocharger position copy sensor
- Vacuum problem
- Variable geometry of the turbocharger jammed in the "maximum turbocharging" position
- Turbocharger: Damaged
- Stickyfinger
AX, little Daffodil
- Contact:
LOL, it is dark
Where is the valve btw ?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
Tock!
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Rear of engine Driver side Alasdair. Guide in case you need it..
Usual - Disconnect Battery
Remove the engine style cover
Click images to Zoom
Refitting
Refit:
Disconnect the connector (at "a"). CAUTION: On each removal, mark the direction of the vacuum pipes. Uncouple the vacuum pipes (as "b"). | Remove:
Refit:
- The turbocharger solenoid valve (1)
- The bolts (2)
- Couple up the vacuum pipes ( as "b").
- Connect the connector (at "a").
- Refit the engine style cover .
- xantia_v6
- My Cars: -
I see from the drawings above that (like the turbo control solenoid on the THP engines) the filter is remotely mounted on the tube that loops upwards, and on mine, the rubber cover over the filter had shrunk, restricting the flow and causing over-boost errors, simply removing the rubber cover fixed the issue.
- Stickyfinger
AX, little Daffodil
- Contact:
That looks get-at-able
Brill, will look in the morning. If no sign of a problem there I will have the car MOT'd asap and order up one from the web.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I’ve got a better diagram of the valve. I’ll put it up when I’m back on my rig.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Bear in mind the part you listed above is the EGR solenoid - not the turbo pressure solenoid valve! They have different part numbers...
1618S5 may be the one you want.... part 18
"m" Outlet to boost pressure waste gate (WASTGATE).
"n" Vacuum inlet (via the vacuum pump).
"p" White marking.
"q" Connector.
"r" Atmospheric pressure inlet.
"p" White marking.
"q" Connector.
