Hi
First time poster.......
I bought a 2004 jumpy II 1.9 D non turbo version. I got the van home and noticed the engine warning light came on intermittently when the engine was under load, normally going up a hill. The van is non turbo but it runs well and has done 140000 Kms.
Borrowed my friends lexus and ran the fault test. It came back with
P0170 intermittent fault, advance regulation, variation in injection advance.
Looking at the live data and the engine advance readings. When idling the engine advance demanded is 2° but the engine advance measured is 10°. The engine warning light is on.
If I then rev the engine slightly to around 1300 revs the figures of demanded and measure are in step or very close to each other and after a couple of seconds the warning light on dash goes out. If then I release the accelerator it goes back to values of 2° and 10° and the warning light comes on again.
Here are the readings at idle
So the engine warning light seems to start comes on at idle when the engine is warm. Also whilst driving I get the light on Intermittently normally when the engine under load. For example when I am going up a hill on 4th and I should be thinking of changing into 3rd.
I would appreciate any help on this issue please?
Citroen jumpy (dispatch) P0170 intermittent fault, advance regulation, variation in injection advance
- My Cars: Citroen jumpy II 2004
Reason: Fixed image placement
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5724
Re: Citroen jumpy (dispatch) P0170 intermittent fault, advance regulation, variation in injection advance
Pop the VIN up and I'll take a look.
Hi
It's....
Is it a DW8 engine?
Thanks in advance
Marcus
It's....
Is it a DW8 engine?
Thanks in advance
Marcus
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
You have DW8B engine: DISPATCH I & II TYPE 800 VAN SHORT 1.9 D 71 (DW8B) Manual gearbox 5
So the fault lies with the advance actuator and is classified as a major fault. A backup mode will be initiated - in this case cutting of the EGR valve. A difference of 7 degrees between the requested advance and the measured advance shows that the ECU is not managing to control the advance. Check the initial timing of the injection pump and if not this, then it is an internal injection pump fault.
Hi
Thanks for the quick reply. I am getting to the edge of my knowledge here. Can you tell me how I check the initial timing of the injection pump please? If it is the injection pump do I just get another one fitted? Could you suggest a part number please?
Thanks in advance
Marcus
Thanks in advance
Marcus
The advance solenoid is a separately replaceable part. I have changed quite a few of them on DW8's, the normal symptoms when they fail are loss of power & engine rattle that sounds like the engine has no oil in it but normally goes away when the engine is switched off & back on again. It only takes minutes to change it, Just literally unscrews out, I remember they used to be very expensive but just had a look on servicebox & it looks like they have went up even more in price. I don't have the chassis number to confirm the correct part no but if its 1563L1 then they are now eye wateringly over £500. Im sure they used to be around the £280 mark.
Before condemning the advance valve check the wiring harness that runs over the top of the power steering pump, you need to unclip it & pull the plastic conduit & insulating tape back, the ribbed conduit rubs through the wiring & damages it, this can cause anything from running issues to complete non start situations, This is a very common problem on the mk1 & 2 DW8 Dispatch/Expert.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Yes that's the part: 1563L1, item 22 - £508.40 from Citroen inc. VAT, but plenty of others here:
https://www.ebay.co.uk/sch/i.html?_odkw ... 1&_sacat=0
That's great thanks for all your help.
So I can just swap this out, don't think I'll be getting the Citroen part. I have read elsewhere sometimes this is coded to the key as anti theft feature. Hopefully my van is old enough not to be?
Could this intermittent fault be causing cold start problem which I am experiencing when morning temp gets below 5°c. It can take a LOT of cranking to get it to fire, white smoke prior to it firing. Glow plugs are getting 12v from relay. Winter coming so need to tackle this issue next.
This Part doesent need any coding, what you have read you are confusing with part 18 in the picture which is a coded part.
Yes this most certainly could cause poor cold starting .
Hi
Finally got round to changing the part but I have exactly the same issue still. Any bright ideas?
Did you check the wiring harness I mentioned?
Can you hear a clicking noise from the valve at all?
