HI all!
I have problem with LDS leaking from rubber pipe above middle back spheres. It is not big leak, it's more like teardrop, but still I didn't pass MOT because of this. For example, I have cleaned everything yesterday and today I can see only one drop at the end of the rubber pipe, as you can see on the photo.
I have been told that this pipe is not under pressure and this is just return pipe, so what I'm planning to do is to cut the part which leaks and connect the good part of the pipe again, because pipe is long enough even if I cut it.
I just wonder, can I safely remove it and is it true that this pipe is not under pressure?
Btw, yesterday, I have checked LDS level and it was fine, just as it should be, between min and max.
The other problem I have is with suspension, I can not lift the car to the highest level. All other levels work fine, car drives smoothly without any problem, I can lower the car, I can lift it to middle high level, but when I try to lift it to the highest level, it just stays at middle high level. I can hear pump is working and after 15-20 sec pump sound changes, so I thought, because of leak there is no enough LDS, but as I said, I have checked LDS level and it's fine.
Citroen C5 x7 LDS leaks and hydraulic suspension issue
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1297
- Contact:
Re: Citroen C5 x7 LDS leaks and hydraulic suspension issue
Yes, you can cut it, just make sure that it is not left under tension.
Check and (wash out with WD40) clean the height correctors front and rear, check the "dog bone" connectors are free (between the AntiRollBar and the height control block)
NEVER GO UNDER a Citroen without Axle stands in position. NEVER, do NOT Be tempted EVER.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 835
That does not look like a genuine Citroen hose clamp, perhaps the hose clamp is causing the leak by unevenly clamping and distorting the hose? It would be easier to try a better hose clamp first.
- Stickyfinger
AX, little Daffodil
- Contact:
Good point, standard screw types are horrible
- My Cars: C4 Grand Picasso 2.0 blueHDI 110 kW Exlusiv 2015
Thanks for reply guys! Pipe was replaced before 1.5 year ago and the work was done by Citroen dealer, so blame on them.
I did wash my car under a few days ago, maybe this is the reason why I can not lift it to the end. I wil try with WD.
Mario Matin
- Stickyfinger
AX, little Daffodil
- Contact:
Only use the WD40 to "wash-out" b the height sensor, use a little oil then a waterproof grease to lubricate it correctly after it has been cleaned.
