RT4 Screen problem
Moderator: GiveMeABreak
- Locked user account
- My Cars: A brilliant C8 2.2 HDi 173
- x 37
RT4 Screen problem
Hi,
I’m fairly new to this so please be gentle ! I hope a picture or a link is attached which should show the screen problem I have got on the RT4 system on my 2008 C8 2.2 HDi 173.
The 1” band appeared first a year or so ago and comes up intermittently with no obvious cause. It has progressively got worse and is now permanently black.
Has anybody else experienced this or have any ideas for a solution ?
All advice or comments would be gratefully received.
Cheers
Cheers
Julian Leyton (RIP) 2023
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5723
Re: RT4 Screen problem
If you gently tap around the pod does it alter the band in any way? I'm wondering if an internal ribbon connector has come loose. Similar bands often happen on LCD monitors over time.
- x 37
Hi Marc,
Thanks for your reply and suggestion however I did try that and it didn’t make any difference I’m afraid.
I’ve also removed the unit to check / clean the plug connectors but that also didn’t seem to have any effect unfortunately.
I thought maybe it was a known problem on these units because I saw on EBay an RT5 display unit for sale with exactly the same problem !
Cheers
Cheers
- My Cars: 2cv6, JIANE, ACADIANE, 2-pot VISA, GSA Break Special, C5II Break HDI175
Is it the hi-res screen or the normal "low-res"?
- x 37
Not certain, but it was what was standard in the car when new in March 2008.
I believe the high res came a bit later
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Pop up your VIN and I'll see what system and connection this uses. If it's the RT3, that uses a fibre option connection whereas the RT4 doesn't. Both systems were fitted to the C8.
- x 37
Thanks Marc.
It’s VF7**************[VIN obfuscated, can be read by forum staff] - I hope that’s the only part of the VIN you need as I only remember that bit (sad, or what ?!) and I’m away from home at the moment.
Rt4 it is. Both the VIN confirm it and the connectors.
Vladimir
Vladimir
Do you have a photo of the screen's back side with some numbers so we can id it?
Vladimir
Vladimir
OK, great. So it is the low-res (DEV) screen.
Unfortunately the new matrix is around 350 USD, so the only option I can advise is get one complete screen second hand.
Vladimir
Vladimir
- x 37
TBH my car has been so brilliant I wouldn’t mind paying that for a new one if it fixes the problem !
Where would I get one at that price ? - when I checked with Citroen it was showing as over £2000 for the complete unit !!
I’ve kept my eyes open on EBay but without success so far.
Cheers
Julian
Cheers
Julian
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, I have everything I need and the full VIN (which I've edited to include). That's one of the last C8s - very nice, I always liked those.
So you do have the RT4 system. Citroen parts don't sell the screen separately for the C8 - the screen is incorporated into the instrument cluster which comes as a complete unit. So the best thing I can think off is searching for a compatible RT4 screen from another PSA vehicle.
I found a few here - but would suggest getting one with as a later manufacturing date to 2008 as possible. There is no guarantee that it will work - but for the £80 £100 price range it is certainly worth a punt. I'm sure you could return it if it doesn't work. Link below:
https://www.ebay.co.uk/sch/i.html?_osac ... n&_sacat=0
The instrument panel is still available from Citroen brand new (Part Number 6103E8) for the sum of: £2357.48! But that does include VAT
So I think you may as well try another screen first. Incidentally did you try the connection from the RT4 Head Unit itself rather than just the one at the screen end?
Another tip - never disconnect the display screen plug without disconnecting the Quad lock connector from the RT4 first - and again connect these up in reverse. The quadlock contains the power source to the screen and connecting these up without disconnecting the power can brick the screens. They can remain active for some time after the engine is switched off.
- x 37
Hi Marc
Thanks again - I’m just going out now so will digest what you’ve said properly later.
I’d seen the Citroen price before !!!!!
Cheers
Julian
Cheers
Julian
