I’m assuming he has the RT4 system as you’ve posted in this thread. If that’s the case you’ll probably need a small programme called Mirascripts to enable the option. This is A small programme written for the RTX range of systems specifically to enable some customisation, but caution is advised as its not official.
ECD5 has done this after upgrading to an RT4, so should be able to help you out.
Is this the right adaptor?
Moderator: GiveMeABreak
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: Is this the right adaptor?
Hi Marc
Yes its the RT4 system.
Is Mirascripts something I can download from somewhere. if so any idea where I might find it?
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
- EDC5
- My Cars: Citroen C5 RHR AM6
- x 120
Yeah, you need to enable the USB either through Diagbox or MiraScripts.
If you've got Diagbox, that would probably be easier but make sure you use a new enough version of Diagbox or you may have an issue. After accessing my RT4 with the newest firmware with my much older Diagbox install (7.63, I think) I now have the issue where the RT4 pops a warning at boot every time! I haven't got around to reinstalling the RT4 firmware as it is a pain in the arse.
Just update the RT4 firmware to 8.31 first, and you should be fine using diagbox up to V7.63 for the configuration.
Let me know if you need any more info as I've used bothe methods before.
Here's the section in Diagbox:
Click to zoom the image
Brilliant, Thanks for the Info, all working a treat now, did it with my diagbox as its the v7.83 one.
I have to say the X7 is a nice car, I drove it the 450 miles to my dads and it is a mile eater, its a 2.0l 138hp but is way more powerful than his old 2.2l and was averaging over 45mpg.
My other half was driving it around for a week just to test it out (have only had it a few weeks but it had to go back to the dealers to be repaired) before I brought it over for him, now she wants one!!!!
- EDC5
- x 120
That's great!
And yes, they're an absolute pleasure on the motorway; you arrive more relaxed than when you've set off
