Hello everyone any help greatly accepted.
As you can see from the title I am not in my neighbours goodbooks. The Alarm keep's activating of it's own accord. Once it was just after I set it (going round closing the door's again seems to solve it) or it randomly activates at any time (99.9 % of the time at night AARRGGHHH). I have just found out from the Neighbour's that it happens quite frequently but the first time I heard it was 4o'clock this morning. Two other thing's that MAY be linked. The boot lock somtimes takes 2 - 5 attempt's before it lock's and also when I unlock the car the Clock reset's itself sometimes.
First Xantia To Get An ASBO.
- My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX - Contact:
Well you could eliminate the volumetric ultrasonics by using the disable button when you lock it. If the alarm still goes off for no reason then at least you will know that it's probably not a duff transducer. Might be worth checking the state of the battery also, and the terminals which are less than reliable.
