C5 HDI 2L 2003 oil tube Removal-Sensors
- ozzdownunder
- My Cars: Current =C5 X7 Limited Edition 2014 HDI, Turbo 2.2L LT Sedan built 2014. Triumph, Holden Commodore, Range Rovers, Rovers.
Hi, checking to find out how to remove the dipstick oil tube on the C5HDI 2003 Diesel. Part of the dipstick is stuck in the tube. Because it is lodged in the bent section its hard to remove it. Other than forcing it into the sump and removing the sump I was thinking, how hard is it to remove the tube itself . Any ideas or pictures to describe its removal without any major parts would be great. As I can see there is only 1 bolt near the top hose clamp. Having undone this did not release the tube, but then I did not force the issue either, just in case I make things worse. On another note, after I removed and externally cleaned the grease from the inter cooler next to the radiator and replaced it the car when driving starts of without the normal power. That is, I think the turbo charger does not kick in until the engine runs for 5min or so. After it warms up it will run normally with the turbo working fine. Could this be one of the sensors that is attached on the top large hose that runs from the inter-cooler to the rear metal connector? If have NOT touched nor changed anything else but disconnected the top big hose that has 2 sensors attached to it, 1 small sensor near the radiator connecting to a small rubber tube and a larger sensor that is fitted inline on the same top hose. All I did was clean out the oil with a rag inside the tube not using any spirits or cleaners, just a clean rag. What are the sensors doing and what do the contacts supposed to look like inside the hose? Any pictures of what these sensors look like with the sensor contacts showing (not the connection contacts) Any input is appreciated, tx
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5644
Re: C5 HDI 2L 2003 oil tube Removal-Sensors
Post up your VIN in the first place and we'll be able to see what's what, as there are several 2.0 variants.
- My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE - x 2500
I'm pretty sure the dipstick tube is just an interference fit into the block and can be removed by a twisting action with a suitable tool.
Man is, by nature, a lazy beast, he does not need twice encouraging to do nothing.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I'm trying to upload a diagram based on a 110 engine, but good old photobucket servers are down again at present. There were several modifications to the dipstick and tubes - but they seem easy enough to detach looking at the diagram (when I can upload it).
At last... This is for the 110 HDi:
There is a turbo pressure sensor at the radiator. Green Denso item iirc.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1280
- Contact:
CLEAN the area very well before you remove it....grit loves little holes !
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
if the dipstick tube (6) is anything like my 2.2 8 valve (it may not be), its anchored into the sump, with an 8mm bolt
I was taking the sump off and the tube was just in the way
with that bolt out I still had to use careful leverage to get it out (an o ring)
John
John
As a matter of interest while the picture is up, note number 5 the dipstick pipe inside the sump, although the dipstick is at the front of the engine it actually dips in the oil at the back, something to think about when you're checking the oil on not so level ground.
