Auxiliary Heater testing Fuel Burning Heater
Right,
The fbh fitted to the HDI, can it be forced to run from a lexia for testing to make sure it works and if not at least I'll get a fault thrown up hopefully!!
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
Re: Auxiliary Heater testing Fuel Burning Heater
I believe (but I am NOT certain) that the Lexia can see auxiliary heaters if fitted. I have seen something about them in a global scan.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
I have never ever played with one in lexia before but have seen the section so am wondering if they allow some testing or such like of the whole unit and if so what test?
- Donor 2023
- x 3008
Pass. Gracie doesn't have any, so I have no way of knowing how they are tested. I just remember seeing something about them, possibly in a 'comfort' section?
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Donor 2023
- x 3008
I DO know you can test the cooling fans on an HDI, as I have done so. Bit weird though, as on slow speed both turn, but on high speed only one turns. Not a fault, as with the A/C on both fans turn at high speed. Based on this, it is possible you can test the heater, but the engine might need to be running, as the heater needs the coolant to be circulating for it to work.
http://www.frenchcarforum.co.uk/forum/v ... =3&t=49752" onclick="window.open(this.href);return false;
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- CitroJim
- My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
- x 6204
- Contact:
I've not seen any Lexia successfully access the heater but it can be tested by linking out its
Sent from my Lumia 900 using Tapatalk
Runner, cyclist, time triallist, duathlete, Citroen AX fan and the CCC Citroenian 'From A to Z' Columnist...
- CitroJim
- x 6204
- Contact:
Control relay in the engine bay fusebox. The relay is controlled normally by the engine ecu and it'll kick the heater into life if the air is below 9 degrees and the coolant below 60 degrees.
- DickieG
- Monaco's youngest playboy
- My Cars:
- x 38
As Jim says you can't fire up the heater with Lexia, just bridging the relay but you must have the engine running. The usual problems that stop the heater running are a duff glow plug, non running venting fan or clogged gauze. If the heater hasn't run for a while it's worth removing it so that you can upend it to empty it of diesel as they can fill up in which case it'll never run. For further info these heaters are used in VW Transporter minibuses so a quick search should reveal all, failing that if you get stuck I might be able to find some for you.
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
So they fill with fuel and won't run! That's stupid!
Does it have no built in pump? I'm just wanting to fire it up to see if it runs. The ones in the rangeys seem light years ahead in comparison
Well best to go and have a play tomorrow when I have a chance.
Any idea which pins need shorting to test fire it up does anyone know?
I know from past reading any fbh needs to be run red hot every now and again otherwise they clog with soot and crud
Fired up the rangey one this morning and by golly is it worth its weight
- DickieG
- My Cars:
- x 38
Yes it has an in line pump just prior to the heater, the heater in your Range Rover is more than likely the very same unit,,,,KP wrote:Does it have no built in pump? I'm just wanting to fire it up to see if it runs. The ones in the rangeys seem light years ahead in comparison
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
Ahhh so the engine doesn't need to run! It can be set to fire and circulate heat within the engine cooling system, albeit upto about 80-90'c before the stat kicks in and let's it go to the front radiator....
This does sound promising!!
- CitroJim
- x 6204
- Contact:
You do need the engine running to test as if the water is not circulating through the heater it'll very soon cut-out due to the over-temperature sensor operating.
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1297
- Contact:
if you have Google translate this is some info from Mother Russia
http://autoklimat.by/product/binar.2917/" onclick="window.open(this.href);return false;
Activa, the Moose Rider
3x C5x7 Steering racks and counting
But if it has a pump Jim is that not circulating or is the pump on a different circuit?
